Dyno Numbers!!Not what I expected or.....
Well gentelman pulled the car to the dyno shop in St Louis.. Ok these are my numbers: RWHP: 386.98 Tourque: 340.33. I'm kinda dissapointed (well really dissapointed) that I didn't reach my goal of 400+. The guy who dynoed the car wouldn't push it to hard because the Fuel pump that I bought was cutting out at a certain RPM and the car had started running dangerously lean. He suggested that I buy a KB boost a pump which I plan on installing at the end of the month. So, I guess my goal of 400 will have to wait until next month but I can honesltly tell you that it is a different car.. Coming back from St Louis I couldn't resist the urge to drop the hammer a couple times. It pullls like a beast! Some time this week I will post the vids and the dyno sheet..It was my first time at a dyno shop and man I had a blast!!! Once again thanks for all the help guys!!
Eh I JUSSSST posted on your other thread. Fuel is MOST DEFINITELY holding you back, what kind of pump do you have because its going to take a killer single fuel pump without a BAP to support that much fuel. You clearly have a setup to make more power than me. I'm a little surprised at the low TQ compared to the HP considering you were pegging your fuel pump. What kind of MAF do you have, and injectors?
How big is your MAF? 80mm, 90mm or more?
I think you guys are a little misguided, he should be making at least 400HP and TQ with his setup or very close. Id be disapointed too. Hes got PLENTY more on tap he just needs the fuel to match the air and spark.
Soldier what fuel pump do you have? Hopefully not stock......if so you shoulda known better haha. Even with my BAP my tuner initially thought with my 36LB injectors and stock pump that I would be maxed and need a pump. I ended up ok. I dont see many used BAPS being sold at all because there aren't very many circumstances where somebody moves to a setup where they no longer need their BAP. Go ahead and buy it new and hit me up with absolutely any questions you have about it. When you get it I suggest wiring the vacuum switch wires together to run it "full time" instead of screwing around with wiring the switch all the way up through the firewall into the boost plumbing. Your tuner should know what this means.
I'm not sure if the vacuum switch comes with non-KB setups or not though.
if your fuel pump is cutting out in the mid 5000RPM range, you're definitely being held back. I believe Scubasteve was running under 400rwhp until he found out he was running dangerously lean, straightened it out, and hit 470+rwhp, just from changing that one thing..
