School me on some fuel.....
#21
OK heres two situations -
Stock motor, longtubes, vortech S trim, CMS stage 1's - What is the most optimal fuel setup to reach 400-430rwhp?
Sitch #2 -
Stock motor, 61mm turbo kit - Optimal fuel setup to reach 400-430rwhp?
Are there different fuel requirements needed for different F/I setups?
Sitch #2 -
http://www.motorsportsdigest.com/tech/perform1.htm This link will help you learn more.
#22
I'm actually not quite sure how much HP a focus pump and bap can support. I read over on corral that a guy said he was running 465hp on a focus pump and bap.
EDIT: I have read that a lot of guys with upgraded fuel pumps drill extra holes into the fuel basket. That way the pumps don't suck the basket dry under heavy loads.
#25
#27
Teej pretty much hit the nail on the head, though i would like to say i am pretttty sure if you get 39s from a cobra you need a special adapter to work on the GTs or even older cobras.
You don't want duty cycles too high, i've been told you don't want them too low either and 80% is a goodish number. For a rough reference
400ish=42lbs
550ish=60lbs
725ish=72lbs
800?+90+lbs
i think i've seen like 110lb injectors before, maybe it was 112, car made like 1500whp lol.
400ish=42lbs
550ish=60lbs
725ish=72lbs
800?+90+lbs
#29
Cliffy Posted up about this a while back, and he showed the calculation for fuel consumption for a given HP level, and what a focus pump for instance would max out at, and the duty cycle of the injectors, etc.
#30
Sitch #2 -
Sitch #2 -
no, not at all. To make power you need fuel and air, the more air (Blower/Turbo etc etc) the more fuel is needed, same amount of air from either resulting in the same amount of fuel needed.
MAF IIRC 95mm will suffice for that much power.
