Upper coolant fill cap on 1997 Cobra
Old 09-16-2012, 08:44 PM
rocket22
rocket22's Avatar
Default Upper coolant fill cap on 1997 Cobra
How do you loosen the cap on the upper coolant fill port for on a 1997 cobra engine? Does it loosen to the left? There is a r on the cap but not sure how to open. I just acquired this car and had to replace radiator. I am going by the cobra book and want to fill at the upper port.
rocket22 is offline
Old 09-16-2012, 10:41 PM
99 GT vert
99 GT vert's Avatar
Only way to get it off is to put a little heat to it, don't do to much then you will melt the rubber o ring
99 GT vert is offline
Old 09-17-2012, 09:07 AM
rocket22
rocket22's Avatar
Default thanks, got the bolt out
I broke off the first 1/4 in drive, so added some penetrating lock eaze stuff, let it sit, gave it a few taps, and used a better 1/4 drive and got it. Should i be putting any anti Seize when reinstalling?
I dont think the PO had removed this in some time. I just replaced the radiator and will do a flush and refill tonight.
rocket22 is offline
Old 09-17-2012, 10:14 AM
99 GT vert
99 GT vert's Avatar
You can put anti seize on it but I'm bit sure if it will help with mine I just took a bolt that had a hex head on it and welded it to the cap.
baddog671
07-26-2016 01:20 PM
Dathan
10-05-2015 05:52 AM
UrS4
10-03-2015 06:23 AM
wraith777
09-28-2015 10:49 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: Upper coolant fill cap on 1997 Cobra
