just got back from my first time at the track
And the gears and the stall aren't gonna do much better without the suspension and tires. I run a 5 speed, stock suspension and tires ran a 2.0, stock suspension and Nitto 315 DR's ran a 1.9, race suspension and M/T 315's ran a 1.759. If I get some 15" wheels, I expect it to be in the 1.6's or lower if I have the power. With an auto you need the stall to get the launch RPM where you want it, you need the gears to help out with the transmission ratio's and get that first gear going on the launch, but you need the suspension and tires to hold it.
Given the OPs power level, he would most likely be able to cut 1.7-8s easily with a set of drag radials on stock suspension with the right level of stall and a set of 4.10s or better rear end gears.
yeah white fox i saw your buddy on the dakota and sorry i did not answer i had a very long day at work and i went to cecil not maple grove and yeah purp i do know what my next four mods are haha
And does anyone on here know how to load a picture of my time slip on here using a mac computer? when i try to it says the picture resolution is too big and idk how to fix that or how to get it on here
I don't know about 12.5s, but you should see anywhere from .5-.8 of a drop in ET by doing a 4.10+ gear install and a 3800+ stall converter. I think you need some weight reduction before 12.5s are really possible given the power you should be making right now. You don't need any crazy suspension/tire setup to do this either. A set of decent LCAs and some MT drag radials should do the trick.
Tires, Tires, Tires.
Don't do anything until you get some DRs. You can easily drop 0.25 off your 60' and thus 0.40-0.45 off your ET just with the DRs. All additional mods will get max benefit if you have tires to hook up with. Gears and a stall would be awesome after the DRs. With 270rwhp, I would think you could get to 12.85 with DRs, gears, & stall.
GOOD LUCK!!!
GOOD LUCK!!!
