The Suspension debate.
lookin to do my suspension. this will be for a supercharged car. i am looking for a setup that will plant the power to the ground but still hit the turns.right now this is what im looking at running.
mm c/c plates
hr ss vert springs
eibach pro damper shocks/struts or coil overs.
steeda bumpsteer kit
i already have full length subframe connectors on the car, sway bars and tower brace installed. looking for opinions on the spring and shocks/struts setup mainly. i dont see this being a bad setup but id like to view all possible options available.
/e: i also am running a full cobra brake upgrade.
mm c/c plates
hr ss vert springs
I would recommend you pick up a good set of LCA's, but depending on how hard you are gonna push it at the launchpad, if this is indeed your goal, you need to consider a strong set. This leads directly to spring/strut/shock choice and need to now your goals for this decision.
I am NOT a 1/4 mile person, but focused specifically on twisties and open track, so hit up my suspension guide and look at "LCA's" specifically for one that will suit your needs.
Jazzer
Jazzer
Jazzer
Jazzer
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
Matt's 95 Stang
10-05-2015 07:16 AM
