ID these wheels pleeze!
#21
#22
Yea, its funny you mention that Jazzer. All of my research towards drag racing with an IRS points to the most failure of half shafts is a stiff sidewall tire or drag radial. The point of running a MT ET Street is that the ripple wall slicks actually absorb a lot of the shock at launch that causes half shaft failure and breakage. If you post over on SVTP, you'll see that this is one of the general rules of thumb to drag racing a cobra equipped IRS car. See, an 03 cobra IRS has 31 spline half shafts to begin with, so they are actually reasonably strong, but the shock of a launch plays hell on them. So you put a ripple wall slick on, it absorbs some of the shock of a hard launch and actually helps keep your half shafts intact. lol didnt make sense to me either...but it definitely works as a lot of guys have less failures with the slicks than drag radials and street tires. Also, the slicks help keep wheel hop at bay.
#23
ok scratch what i said those wheels are different from the normal steelies that people put on trucks i believe they are a dragon?? brand wheel i remember reading about them and they are not as heavy as the old school steelie wheels
#26
I am curious about one thing though and asked this question just the other day re: half-shafts and digging off the line. I don't really understand why the IRS is soo vulnerable to this issue, while the SRA is not...? I mean, what is the difference between the shafts of the IRS and those of the SRA? I cannot find any difference, except "maybe" some better support so as to not "flex" as much as the IRS...?
Bueller.... bueller....?
#27
Well seeing that the half shafts are not one piece like the axles of an SRA, and that the half shaft flexes on launch, thats pretty much the reason why. They have CV joints in the half shafts that can be weak stock and can have some play. When they receive the full shock of a hard launch, they can break. There are halfshafts on the market that use porsche style CV joints with stronger internal cages and races and thicker center bars, but they are $2000 for the set of two, but are good for 1000rwhp. Stock pieces can hold plenty, just dont use a stiff sidewall tire and launch the hell out of the car.
#29
I think its both really. Its partially the shock and partially the wheel hop because you're not hooking. So in reality, the slicks get rid of both so its hard to tell which it really is in the end. I mean with hoosier and mt drag radials people dont have hop but they still break half shafts. So who knows.
#30
This is an incorrect statment, a wrinkle wall tile winkles because the tire is biting an propelling the car forward and even enough to pick the front tires off the ground instead of just spinning the hell out of the tires and getting a poor launch. There is no "loss of power". But by the context of your post I assume you were kidding.
