4.6L 2v is fast?
310rwtq my ***. He was probably guessing what it produces at the flywheel. Stating your horsepower at the flywheel is like measuring your dick starting at the bottom of your *****. Its BS.
EDIT: Doug (whitefox) states his horsepower to the flywheel when talking about his car.
Purp coudln't have said it any better. You should write a book man. You would make millions....
First, I don't think his mods would produce anywhere close to 268rwhp on a 2V motor.
Second, torque is a function of HP and RPM, so if you make HP a little lower in the RPM range you will make higher torque numbers (diesel trucks are a great example).
Third, 0-60 times are quite relevant. It is the 60' time plus the shift and second gear pull. This is probably a real good measure of street performance.
michaelkott
Ohio Regional Chapter
07-28-2013 06:17 PM
