spec stage ? or mcleod twin disk
Mcleod no questions asked. And please don't pay 650 for a used clutch when new they are 700. Now to the gu with the s197 I know a couple people that put the mcleod clutch in a hydraulic clutch setup and had no luck with it but with the t56 they are great. There is no pedal pressure my svt contour has a harder pedal pressure.
And when asking what the difference is between a single disk a dual disk for the power the op is going to be putting down a twin disk is going to be 100x more streetable than a single disk clutch.
The explanation I was given is you have more leverage with a twin disc then a single. No matter what the explanation, the outcome with a twin over a single disc is that you have a clutch capable of holding much more power with much less pedal effort.
Well I installed the RST when I put a TR-6060 in my s197...similar to the T-56 and the new T-56 Magnum....all have 26 spline input shafts. So I can say for certain that it didnt work for me. The 10 spline for the TR-3650 may work better, but I cant comment on that since I didnt try it. also...maybe for the older platforms they are working out, but I wont ever try the RST again in my current s197 car.
jwog666
12-27-2021 08:09 PM
junior04
09-28-2015 10:53 AM
09-25-2015 09:06 AM
