Plastic bag stuck on exhaust pipes
Old 12-30-2010, 10:09 PM
StriderTacticaL
StriderTacticaL's Avatar
Default Plastic bag stuck on exhaust pipes
Has this ever happened to anyone else before? It is the worse thing in the world. The smell of burnt plastic in the interior is unbelievably nauseating and I felt like I was about to pass out several times. It's happened once before with a smaller plastic bag and as soon as I noticed the all-too-familliar smell just now when I was driving, I knew exactly what it was. I looked under and I must have picked up a small industrial trash bag or something cause half my X pipe is covered in white plastic.
Any ideas how to remove the stuff once the car cools down? I know the plastic melts and becomes hardened and it looks like a bitch and a half to deal with.
It will be like this for days just like last time...and I won't be able to tolerate it...
Brandon
StriderTacticaL is offline
Old 12-30-2010, 10:23 PM
bopiela
bopiela's Avatar
I'm actually surprised this doesn't happen more often with all the stuff people throw out onto the streets.... Wish I could help... You could try chiseling it off if it actually hardens... (my best guess, haha)
bopiela is offline
Old 12-31-2010, 04:36 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
It has happened to me 3 or 4 times--when quite bad I have used a scraper to get off the worst of it (easier when the pipe is hot) and then just live with the stink 'til it finally burns off--a good 20-30 mile run on the interstate usually gets rid of most of it.
It is one of those instances where you wish there were someone to grab by the neck...
cliffyk is offline
Old 12-31-2010, 05:59 AM
devongarver
devongarver's Avatar
Acetone(the pure ****, not watered down nail polish remover) will dissolve many plastics. Gasoline will dissolve some things. Oven Cleaner will also work. I would try the acetone first, but WEAR SAFETY GOGGLES. You do not want that crap dripping in your eyes...
devongarver is offline
Old 12-31-2010, 07:23 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Unfortunately the damned things are made of polyethylene; either low density (the somewhat stretchy ones) or high density (the stiffer ones that crackle a bit), both of which have very high chemical resistance.
In the table in that link the ++ symbol means that the listed chemical has no effect on polyethylene.
cliffyk is offline
Old 12-31-2010, 08:47 AM
JRad405
JRad405's Avatar
What about goof off? That stuff eats through plastic and just about everything else.
I wouldn't use it on the painted portion, but being that you have it on your exhuast pipes I would try it on that.
JRad405 is offline
Old 12-31-2010, 10:33 AM
devongarver
I thought about that stuff...but it's really just citric acid I think, and may not even be as strong as the acetone is. Meh...if it was me I think I would just burn it off and be done with it.
Old 12-31-2010, 11:31 AM
2k1gt
2k1gt's Avatar
It has happened to me before. I just had to suck it up for a few days, but it went away on its own.
2k1gt is offline
Old 12-31-2010, 03:28 PM
TRUEBLUE3934
TRUEBLUE3934's Avatar
Might try a rotating wire brush attachment for drill or air tool...
Good luck!
TRUEBLUE3934 is offline
Old 12-31-2010, 03:35 PM
TOOT
TOOT's Avatar
Originally Posted by TRUEBLUE3934
Might try a rotating wire brush attachment for drill. Good luck!
This is what I used.
TOOT is offline
Quick Reply: Plastic bag stuck on exhaust pipes
