new shifter?
new shifter?
ive been looking alot at new shifters and short throw shifters and was wondering if their worth it. since my cars a daily driver should i get one and if so which should i look for? thanks for the input you guys are awsome
I bought a tri ax for my 2000 gt and it is amazing. No more missing 3rd and it is as smooth as silk. I have a steeda but I have heard good things about the mgw as well. Get off the fence. This is a mod that once you do it you wonder how you ever got by without it
MGW is very tight and precise. The Steeda feels just like stock, but shorter and with a better center aligning spring. I have the steeda, I want the MGW. But we'll see after I try the Pro 5.0 handle I got as I'm still using the stock shift arm.
Steeda shifter features a LIFE TIME warranty. We revise the pivot ratio so the throw is shorter then stock.
It's an easy install, just pull up on the shifter boot bezel and remove it. Then the rubber boot underneth. Finally the shifter is only attached to the top of the transmission with 4 bolts. Shouldn't take more then 30min.
Scott
Scott
It's 4 bolts to remove....and the steeda feels nothing like stock... Way tighter... Goes back to center on it's own. Why install it if it is the same as stock. Mine feels nothing like stock. WAy more precise and when on the street and the hondas pull along side I have yet to miss 3rd since I got it
