i would spend a little bit of money and buy an sfi rated overdrive pulley. they run about 400 bucks.
just my .02
I want to do an overdrive crank but talking to a few that have done it (Jivepepper) you'll go through an alt once a year so a few PSI more boost ain't worth it to me
the belt size i dont know on size. i dont really know how much lead way the tensioner has. i would assume if upgrading to a o/d pulley and/or bigger alt pulley( to balance out the proper rpms so not to burn it up) would more than likely need a longer belt
Yes and in turn would slow it all down so the benefit of the overdrive crank pulley is not as much gain boost wise and just becomes a 400.00 dollar harmonic balancer
only good thing about that is that it would be safe to run under 11.0s at the track =)
