Pics of my Clutch install
The throwout bearing went out in on the way home one day, decided to take the project on myself. Here is a vid of the noise it was making followed by pics of the swap.
Clutch Noise
Got the flywheel resurfaced for $40 bucks.
Bought the center force dual friction clutch $350
Tried to put the clutch in last night by myself but that was a joke it was hard as hell and kept slipping on the stand I made. So I will try it again tonight with some help.
Clutch Noise
Nice pics ,Wow that TB was gone and looks like it did some damage to the input shaft also.
But why is that tranny fluid so black in color?
I would think it should be redish in color useless use used royal purple then I can see why its that color
yea when I pulled the pressure plate all the bearings fell out, trans fluids black cause I never changed the trans fluid out, doubt the previous owner did either. the Input shaft is good it was just dirty I cleaned it off very good the new throw out bearing is on and slides very smooth, I did replace the fulcrum stud (clutch ball) it had a groove in it.
Good work doing it yourself. I wish I could have changed mine myself, but I never have a day off from work on the weekends, and I'm away at school during the week. But my TOB is squealing again and I had the clutch and new bearings put in about 1k miles ago. Dropping mine off Friday for them to put in another bearing (Yay for warrantys)
damn wish i would have know that yesterday evening, we finished everything up I took it out for a test ride, but the clutch pedal needs to be adjusted the clutch is not biting. its slipping under load.
