Guess what I'm doing tomorrow!
#23
I only used royal purple once and $2100 later I had a new engine. My car sat for 4 months while I was out of the country and because I had royal purple in it 5 of the valve seals dry rotted and I burned thru oil so fast that I spun a bearing (less then an hour of driving). Dino oil is to only oil I will ever use now in any of my cars or trucks.
#24
#27
Since we have a ford tech posting, I might as well ask what the importance in weight is. I forget the reasoning, but I was told that you don't want to run a higher weight than the 5w-20 that ford specs, so that's what I've been using.
#28
I love when people randomly come in with some horror story about this oil or that one. And in my defense I didn't feel like a tightened the bolt very tight before it popped and was stripped. I guess through all the oil changes over the years it was probably overtightened a few times.
#29
For an 02 mustang, Ford recommends 5w-20 for efficiency and to meet CAFE regulations. You'll hear a lot of people say that beginning in 01, Ford changed the spec from 5-30 to 5-20 because internel engine tolerances changed, but that holds no water.
Both oils will provide the same start up flow and pressure, however after the engine is at temp, the 5-20 will be thinner than the 5-30. 5-30 would be best for high rpm usage because it will hold oil pressure better, I'm talking in the 6k+ range.
In the end, either oil will do for a daily driver that gives the car a few WOT runs.
EDIT: Now, for the 05+ guys, they spec 5-20 not only for the efficiency, but also for the VCT. 5-30 can play games with the VCT, and cause some issues with the cam timing.
#30
2010 Blue Ball Award Recipient
boom to you guys..
<<<<<<<this guy doesnt need ramps OR a lift to change his oil..
crawl your *** under there *non lowered guys* and stretch your arm out...mmm..yah!...feel teh scrape on your back as you wrench your body out from under there..
