A Few Brake Questions
Old 02-23-2011, 02:46 PM
Bpohlman13
Bpohlman13's Avatar
Default A Few Brake Questions
Will I am going to upgrading the brakes on my car in about 3 weeks. This is when I'm going to install all of the parts I recently got for my car(Nitrous, cams, 4.10s, flsfc's, and lca's.). Only reason Im waiting untill then is that it will be spring break. I was wondering if you guys have seen the rear cobra brake conversion without the rotors? I already have some new slotted/ drilled rotors I picked up for it. What pads would you guys suggest? I want very little brake dust if possible. Last but not least, what brake fluid should I change to?
Bpohlman13 is offline
Old 02-23-2011, 03:48 PM
natedog
natedog's Avatar
Here http://www.buyfordracing.com/shop/pr..._id=631cPath=6 is a link to a set of loaded calipers. Prob won't find them much cheaper. I don't know that you will find the conversion kit without rotors. If all else fails, just resell them.
I bought front the fronts a few months ago from this site, and the pads they came with shed almost zero dust. I assume the rears come with the same type of pad. If you really want good pads go with Hawk... that seems to be a common choice here.
natedog is offline
Old 02-23-2011, 06:02 PM
LilRoush
LilRoush's Avatar
Cobra rears are stock calipers relocated outward and thinner pads to address the extra thickness of the rotor. All you need is the bracket to move them for your already purchased rotors.
LilRoush is offline
Old 02-23-2011, 06:36 PM
Bpohlman13
Bpohlman13's Avatar
Ya I know, but the kit also comes with rotors. Also, do I need different bang bolts for the front or rear
Old 02-23-2011, 09:25 PM
LilRoush
LilRoush's Avatar
Don't buy the kit, just buy the brackets you need.
LilRoush is offline
Old 02-23-2011, 09:26 PM
Bpohlman13
Bpohlman13's Avatar
I dont need the moans things?
Tivo304
08-28-2023 12:19 PM
DoctorScary
09-09-2015 07:53 AM
09-08-2015 11:50 AM
Quick Reply: A Few Brake Questions
