Nitrous guys please help Im really confused
uh yea mark... your not SUPOSED to spray undr 3k.... you on the other hand.... dont care haha
i usually have my **** kick on at 2800 and off at 6200.... but its a stick car... different story lol
Like mentioned above it's wired to the throttle body. The only really good reason for you to run a window switch with the auto is so you don't spray at to low of a rpm. That really isn't a good thing, but with a smaller shot it would most likely be okay.
the window switch is getting thrown in with the kit for a extra $20 so i mind as well do it.
And what are some tips on maintain a nitrous setup, and maintaining my motor while on nitrous?
And does anyone recommend a lean shut off? Or is it not really necessary?
Honestly, if you're just running a 75-100 shot there's not a lot you need to do. Change your plugs and check them every so often, make sure the solenoids and fuel system stay in good working order, and have it tuned. Maintain the car like you normally would. The lean off switch is not necessary at your level.
For as cheap as it is, especially for the HSW controller, it would be a good idea/investment.
