Suspension Opinions!
Whats up guys, I am in need of some opinions on what to do first for my suspension. So far all I have are H&R supersports and MM FLSFC's. I will be setting my car up with only cornering in mind.
The next things I want to do are either some Bilstein HD shocks and struts or a MM PHB with MM XD LCA's.
As of right now the ride quality could definitely be better since I still have the stock shocks and struts but I also get pretty tired of having a hard time putting all of the power to the ground.
Also if anyone has experience with these, the LCA's come in either adjustable or non adjustable. The adjustable ones are more expensive but are they worth the extra $100 or so?
Links:
Bilsteins: http://www.maximummotorsports.com/st...oducts_id=1371
LCA's/PHB: http://www.maximummotorsports.com/st...roducts_id=339
http://www.maximummotorsports.com/st...roducts_id=338
Opinions??
Links:
Opinions??
I would go with the struts and shocks option. Since you have springs struts and shocks will help out a ton. LCA are also very important, you wont need adjustable if you are not pure drag racing. Some times people use the adjustable portion to use larger diameter rear wheels.
He's talking adjustable as far as ride height adjustable it concerned. Ride height adjustment is needed to corner weight the car and properly set it up for taking the twisties. I'd suggest the shock and strut upgrade as well.
