whatever u do don't strip out a header bolt!
Old 03-12-2011, 03:25 PM
Blk003GT
Blk003GT's Avatar
Default whatever u do don't strip out a header bolt!
i stripped out a header bolt SOMEHOW it was a PITA to fix it. i had to drill through the manifold and into the head and then run a bigger drill bit just thru the manifold so the tap would fit thru. used a 3/8" into the head (meant to only run the 3/8 thru the manifold but went a little far) and then used a bigger drill bit thru the manifold. then ran a 12mm 1.75 tap into the manifold and head(soldered the tap into a socket and used a rachet with oil on the tap) and then put the bolt thru. it acutally worked. so hopefully it holds. its a big thread pitch so i shouldnt have any issues but it was a real pita. woulda been easier if i would have taken the manifold off but i was too lazy to do it lol. i was just excited that i fixed it relativly easy
Blk003GT is offline
Old 03-12-2011, 03:30 PM
Moonshine
Moonshine's Avatar
HA! Did you cross thread it or are you so strong you really...stripped it.
Moonshine is offline
Old 03-12-2011, 05:16 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
4.6 manifold studs snapping are a super common issue. You do know that its an 8x1.25 thread right? Lol you musta hogged that hole way out
WhiteFoxGT is offline
Old 03-12-2011, 06:14 PM
Moonshine
Moonshine's Avatar
Stripped and snapped are pretty different.
Old 03-12-2011, 06:33 PM
Blk003GT
Blk003GT's Avatar
NO clue how it happened. It just stipped. Ya I know its way bigger I didnt mean to drill it out that big
Blk003GT is offline
Old 03-12-2011, 07:08 PM
PurpleIcedGT
PurpleIcedGT's Avatar
"well why dont ya cry abt it?" -ace ventura
PurpleIcedGT is offline
Old 03-12-2011, 07:11 PM
Blk003GT
Blk003GT's Avatar
well i already did lol
Blk003GT is offline
Old 03-12-2011, 08:09 PM
Moonshine
Moonshine's Avatar
I usually spin bolts/nuts counterclockwise til I feel a click then thread in. 60% of the time it works every time.
Roger Mabry
06-15-2016 08:27 AM
GimpyHSHS
08-29-2015 06:30 PM
91StangOwner
08-20-2015 11:34 PM
Valkdriver
5.0L V8 Technical Discussions
08-13-2015 08:57 AM
Quick Reply: whatever u do don't strip out a header bolt!
