No to the CENTRI!!
No to the CENTRI!!
This is all ripped straight from MODDEDMUSTANGS.com
I'm entertaining the idea of having an eaton atop my teksid. I know that a CENTRI kit would be easier, but I'm really not interested in a CENTRI. Like..at ALL.
What I know is that (to my knowledge) there is no roots style blower kit for a 96-98 cobra. Well here it is. Let's discuss.
_____________________
Easiest way to do it is pull your engine out and get terminator long block and drop it in.Even if you get 03-04 cobra supercharger that's probably 1/10 of your total swap cost.You also need 99+ cobra heads.Your bottom end and tranny are weak and those are the first things which will go after the swap.
Here is the part's list that would be needed when doing the supercharged 03 cobra swap on 99-01 cobras and 03-04 Mach 1 .
(6312) Crank pulley /Harmonic Balancer
(6312B) Supercharger Crank drive pulley
(8678A) Pulley w/mount Replaces stk. alt. Pulley on 99-01 Cobra’s and 03/04 Mach 1’s
(6B209B) Pulley bridge assembly for S.C.
(8678B) Idler pulley,timing cover LH side
(6D080) Timing cover
(10A313) Upper alternator bracket
(10153) Lower alternator bracket
(10346) Alternator
1U2Z-14S411-TA Electrical connector (alt. to harmness )
(6B209A) Tensioner on timing cover
(8260) Radiator hose
(8A593) Radiator hose
(8K576) Radiator hose
(8548) Water cross over pipe
(6881) Cobra oil cooler adapter
Note: Use your stock gasket from your adapter or a leak will occur
with a Cobra gasket!
(6A642) Cobra Oil cooler
(9002) Cobra fuel tank
(9H307) Cobra fuel pump
(6F066) Eaton supercharger
(9424) Lower intake
(6K775) Garrett factory intercooler
3U2Z-14S411-JUA IAT sensor connector
(9H308A) Intercooler hard lines that hug the block
(9N491A) Intercooler hard lines that come from the h/e
(9L443A) Intercooler pipe to heat Exchanger that goes from the i/c adapter to i/c res.
(9L443B) Intercooler pipe to heat Exchanger that goes from the i/c adapter to the hard lines that hug the block
(9L443C) Intercooler pipe to heat Exchanger that goes from the hard line to i/c pump
(9L443D) Intercooler pipe to heat Exchanger that goes from hard line to hard line coming from h/e
(9L443E) Intercooler pipe to heat Exchanger that goes from hard line from h/e to i/c pump
(9L443F) Intercooler pipe to heat Exchanger that goes from hard line and connects to h/e
(9L443G) Intercooler pipe to heat Exchanger that goes from hard line and connects to h/e
(8501) Ford / Bosche water pump for intercooler
(8K226) Factory heat exchanger
(8A193) Heat exchanger mounting bracket
(8C386) 2each bracket clamps for h/e
(9N491B) Lower manifold to intercooler water adapter
(9A589) Plenum
(9E926) Throttle Body
(9B659) Intake tube from maf to t/b.
(9F715) IAC valve
(9F593) Injectors
(6F089) Boost bypass actuator
(8N500) Intercooler pump bracket
(9A825) Cruise control cable
(9A758) Throttle cable
(9728) Throttle and cruise control cable mounting bracket
(12B579) MAF
(9D475) EGR valve
(9D477) EGR tube
(6C324) PCV tubing
(9F479) Sensor on the back of the S/C
(9J432) Bracket for vacuum stuff on left side of the S/C
(9H465) Vacuum stuff
(9J459) Vacuum stuff
(9J460) Vacuum stuff
(9E498) Hose's or tube cluster of connectors for the vacuum parts above
(9F670) IAC gasket
(6020) Timing cover gasket LH side
(6020) Timing cover gasket middle
(6020) Timing cover gasket RH side
(9H486) Intercooler to S.C. gasket
(9L437) Plenum to S/C gasket
(9D476) EGR gasket
(10346) Alternator
(9424) Lower intake
(9A589) Plenum
(9F715) IAC valve
(9F593) Injectors
(12B579) MAF
(9D475) EGR valve
(9D477) EGR tube
(6C324) PCV tubing
(9F670) IAC gasket
(9D476) EGR gasket
Uh... the second option seems to be a little more involved lol. Unless time and money are not a problem, i'd go with the centri of those two choices. Or like purp said just spray it for really cheap.
Why are you not liking the centri?
Seems like you could figure out a cheaper way if you created something new based on that blower instead of more or less swapping the 03/04 set up.
Spray isn't always the answer. If you ever put the car on a track that isn't a straight line, the nitrous is useless. It's also not legal to use on the street, where as a SC is there and you can tap into the power level you want at any point.
Id throw a centri at it for that. Seems like A LOT less hassle.
And yea we all know that nitrous isn't the answer for everything...it's just a cheap option to get some power for awhile (at least for me).
Thats why you build a nasty motor N/A so you can have fun on and off the juice
You can find complete Cobra motors for around $3-4k and you could piece one together for a lot cheaper. You also could find a complete top end from either a Cobra or Mach 1 for much cheaper and use your current block and the compression would drop a little, probably right around where you would want it with a blower.
That lists makes things look extremely complicated and overwhelming, but if you can find a complete motor or top end that pretty much eliminates everything on that list minus the blower stuff.
Way to go wannabe!
Like I said, I don't wand a CENTRI. That stupid whistle is SO annoying to me. I want to do something irregular. I will not be replacing my rods or pistons as I only plan on being in the thereabouts of 400 wheel. My car as it sits has more than enough power to get me into some serious trouble.
I've been looking at a steigemeier stage 5 ported eaton a guy has for sale locally. A decent price as well.
As far as it being a pita to do...so fuggin what? Anything good in live you have to work hard at. This applies.
@lilroush Is your eaton your doing, or it came that way?
@purp No.
@purp No.
