do i have isos?
Old 03-22-2011, 10:59 PM
Repzard
Repzard's Avatar
Originally Posted by DarkShadow04
thats VERy possible...i dont know the guy i bought the car from at all so it's possible, although it seemed like he took good care of it i cant be too sure, i know he installed the springs himself
maybe your confusing a alignment with bumpsteer as for the front goes.?
does the car wonder on wavy or bumpy roads?
if it does you need a bump steer kit.Unless your have one then id go get a alignment like others suggested.
GL
Repzard
Repzard is offline
Old 03-22-2011, 11:01 PM
DarkShadow04
DarkShadow04's Avatar
no, front tire wear is telling me i need an alignment...it was discovered while installing my new clutch cable that the insides of my tires were worn down to the metal, and the outsides were still showing some tread... i havent driven the stang really since october but i dont remember that feeling over bumps, its only on the 1inch pro kit so i believe i dont need the bump steer? could be wrong maybe?
DarkShadow04 is offline
Old 03-22-2011, 11:29 PM
Repzard
Repzard's Avatar
hpwrestler220 reccomended camber bolts.
Those are another way to set chamber on the Mustang instead of CP.
The bolt have like a "cam" on them say -2 degrees that set camber to what ever the cam degree is.
I believe they install on the strut where it connects to spindal knuckle.
Also I heard of people drilling out the holes longer where strut connect to tower like chamber plates to get a few more degrees. dont think Id go that route.
Repzard is offline
Old 03-23-2011, 03:49 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Camber bolts are also known as "crash bolts"--here's my observations and opinion about them from another thread...
cliffyk is offline
Old 03-23-2011, 08:09 AM
turbo232
turbo232's Avatar
what he said. do it right. cc plates dont cost that much. search ebay.
turbo232 is offline
Old 03-23-2011, 10:53 AM
DarkShadow04
i dont necessarily know if i need CC plates as i dont know if that is a problem, however thank you for the info...i know i am in need of an alignment but dont know if i would really benefit from CC plates
Old 03-23-2011, 11:56 AM
hpwrestler220
hpwrestler220's Avatar
Only way to find out is to get it up on the alignment machine
hpwrestler220 is offline
Old 03-23-2011, 01:34 PM
69MustangCoupe393cid
69MustangCoupe393cid's Avatar
I bet the alignment was just never done. The factory stuff based on what I'm told will still align ok with the pro kit. I'll find this out as soon as I get time to put mine on. But I vote to just take it to an alignment shop and have them do it.
69MustangCoupe393cid is offline
Old 03-23-2011, 01:41 PM
Repzard
Repzard's Avatar
Great info Cliffy
Repzard is offline
Old 03-23-2011, 06:44 PM
DarkShadow04
yep, goin to order my new tires tomorrow i think, then ill be getting it aligned, we'll see what happens
Quick Reply: do i have isos?
