Auto Meter Pro-Comp Ultra-Lite Air/Fuel Ratio Gauge - Electric Install
I was looking into getting this. Anyone have one of these. How exactly did you install it. step by step..? Im not a mechanic but this shouldnt be to hard of an install??? http://www.americanmuscle.com/autometer-airfuel.html
PS I have a 02 GT
PS I have a 02 GT
That gauge is just a narrow band sensor light show, worthless for anything but impressing people that don't know any better.
You'd be better off to save up another $100 and get a wide band O2 system.
However if you insist:
Go to Autometer's site and download the instructions.
The easiest place to tap a narrow band sensor is at C133 at the passenger side rear of the engine compartment:
at pin 5:
The wire is gray with a light blue stripe (GY/LB), and carries the output signal from the passenger side front O2 sensor. You'll need to disconnect the battery and remove a 10mm head bolt that holds the connector together, then remove the top plug. Strip the harness sheathing back a way from the plug, and find the GY/LB wire, tap into that.
at pin 5:
