What PSI until i start floating valves?
Can be in high rpm n/a setups. But in f/i setups its very common if you run high boost on stock or not very stiff valve springs. Its not usually recommended to use stock valve springs in boosted applications but if you're using mild boost you should be fine up to like 12ish psi.
The stock Valvetrain is good to 8k+ rpm. Anyone has anything to say that says otherwise is a noob and needs to go back to pushrod motors.
OP, clarify what you're talking about if you're not talking about valves & cam followers. The cast crank is good up til around 750hp maybe more but I don't know anyone that has went through all the trouble of building an engine and kept the cast crank. the Rods are good till about 450rw and the pistons are good right up until you detonate.
A blower is going to be a different scenario than a turbo. You shouldnt have as much of a problem with a blower as you would with a turbo. What the ops worry is about is the back pressure from the turbo floating the exhaust valves. I would talk to nick at mhs, he's got plenty of experience with turbo cars to tell you what he believes the safe level of boost is before this occurs.
