Nitrous is working
Old 04-29-2011, 08:44 AM
huey_33
huey_33's Avatar
Originally Posted by tim2002gt
If the line was leaking, you probably weren't even getting a full 75hp worth of nitrous. Probably was running ultra rich like that.
Btw, what size are the jets you are running? My kit uses a .044 nitrous jet and a .028 fuel jet for a 75 shot. Basically, I'm wondering if your kit is rated at the crank or at the tire.
The 75 shots jet that were on the car are .042 and .024 while the 100 shot jets which are now on the car are .048 and .028. Now I have a quick question. When I took the car out last night and when the nitrous kicked in, the car shifted (automatic) at 6500RPM's. What is a good RPM on and RPM off to set the window switch at to ensure the nitrous don't cut out during my runs? I was thinking on at 3000RPM's and off at 6500RPM's.
huey_33 is offline
Old 04-29-2011, 09:00 AM
Kmelfi11
Kmelfi11's Avatar
Your RT doesn't effect your 1/4 mile time. Sometimes its better to not go for a good RT so you can focus on your launch. does 6500rpm seem a little high to anyone without cams?
Kmelfi11 is offline
Old 04-29-2011, 11:10 AM
huey_33
huey_33's Avatar
I keep reading that anything over 6000 RPM's is too high. So I'm about to change my shift points to around 5000-5500 and see how that works.
huey_33 is offline
Old 04-29-2011, 12:13 PM
mrtstang
mrtstang's Avatar
I run mine from 2800-6000 rpm. It's worked like a charm since day one.
mrtstang is offline
Old 04-29-2011, 12:32 PM
TRUEBLUE3934
TRUEBLUE3934's Avatar
On the dyno, .046 / .028 jets gave me a good A/F and made 70rwhp increase.
I would STRONGLY suggest putting the car on a dyno to figure out the correct jetting combinations for A/F ratio and actual rwhp increases.
For what it is worth, it took .060 / .035 jetting to get a good A/F and 100rwhp increase on my car.
LOL I said to get a 100shot tune, becasue I knew he would have the 100 jets in it very quickly.
TRUEBLUE3934 is offline
Old 04-29-2011, 01:55 PM
bigbadstang
bigbadstang's Avatar
What kit u running?
bigbadstang is offline
Old 04-29-2011, 03:42 PM
huey_33
huey_33's Avatar
Originally Posted by bigbadstang
What kit u running?
http://www.dynotunenitrous.com/store...?idproduct=254
Running that with an MSD digital window switch 8969 and my purge kit is coming tomorrow. Everything together has probably ran me around $700.
huey_33 is offline
Old 04-30-2011, 12:41 AM
tim2002gt
tim2002gt's Avatar
Really? Do you think it was because of the cams you are using? I am using a .057 nitrous jet and a .032 fuel jet and I picked up 128 rwhp with an a/f ratio just below 12:1. I ran back to back pulls with the same tune with and without the nitrous. Motor pull was 250 rwhp and nitrous pull was 378 rwhp. Torque was 292 and 474 ft/lbs.
tim2002gt is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
FivePointToTheOh
10-02-2015 04:09 PM
Pyrate Dave
09-10-2015 07:30 PM
JoshyGT
09-07-2015 02:04 PM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: Nitrous is working
