School me on N20
School me on N20
I know how you make power from N20 but there are a few things I'm not sure about.
1. What is the major diffrence between a nozzle system and a plate system?
2. How large of a shot can a stock bottom end hold up to?
3. How much is to much without a tune? Also does that matter where its injected in at?
4. How much of a difference does a bottle warmer make?
I'm sure there are other things but right now those are the ones that are on the top of my head. Thanks in advance guys.
^Tell the meatball above me to eat shlt. I'm looking for a link to moddedmustangs, over there a member Baznastydave made a really cool write-up about nitrous and everything you need to know about it.
http://www.moddedmustangs.com/forums...s-qs-info.html
Hope that helps...
Hope that helps...
1. A plate system is supposed to give a more even distribution.
2. 150 if the tune is spot on.
3. A lot of guys get away with a with a 100 shot untuned, but i wouldn't do it personally. Most kits are setup to spray before the throttle body.
4. A bottle warmer is a must for temps below 60-65 degrees. Makes a big difference if the the pressure isn't where it should be.
stangin1996gt
09-21-2015 11:01 AM
