96 gt running BAD check engine light not on???
Old 05-06-2011, 01:29 PM
mustangbert
mustangbert's Avatar
Default 96 gt running BAD check engine light not on???
my car runs good at steedy speed then when i step on it it falls on its face and seams like its running on 5 or 6 cylinders any help would be greatly appreciated thanks
mustangbert is offline
Old 05-06-2011, 02:41 PM
jwog666
jwog666's Avatar
if the light is on get it scanned so you know the code. diagnosing a vehicle without knowing the codes is a waste of time.
jwog666 is offline
Old 05-06-2011, 03:25 PM
wolverine8490
wolverine8490's Avatar
I will guess water or anti-freeze in the spark plug holes. That is the first thing I would check...
wolverine8490 is offline
Old 05-09-2011, 02:20 PM
mustangbert
there is no water/antifreeze in the spark plug holes the check engine light did come on today so i read the codes there was 2 codes one was p0308 which is cylinder 8 miss fire and the other is p0308 p and i cant find anything online to tell me what that code is??? any one know??
Old 05-09-2011, 02:48 PM
darkstarnes
darkstarnes's Avatar
well there is your problem cylinder 8... swap the coils to see if the problems follows the coil to diagnose... if not than it may be sparkplug.. or wires for coil or fuel injector...
darkstarnes is offline
djbigskrilla
09-20-2022 01:04 AM
microgt
08-20-2015 07:12 AM
kevans79@yahoo.com
08-18-2015 08:16 AM
mweiland
08-13-2015 05:11 PM
drumhedd2005
08-13-2015 09:59 AM
Quick Reply: 96 gt running BAD check engine light not on???
