View Poll Results: next mod?
Suspension Kit, Springs/Shocks/Struts and Sway Bar
50.00%
Cams
35.71%
Typhoon intake manifold and 75mm throttle body
7.14%
other
7.14%
Voters: 14. You may not vote on this poll
Next mod opinion needed.
I would say cam it for now. The MM Road & Track package is nice, but costs a good chunk of change. Check out Modular Headshop, if you want to get a custom grind, I've got a set of PI cams lying around that you can send out while keeping your car on the road, then I'll swap you for your stockers.
Absolutely do suspension. It's going to make your car look 10x better, but it's an EXTREME upgrade in performance...
Bilstein HD's all around, H&R SS. Then get some cobra brakes. Those will be your favorite mods to date
Some good brake pads, SS lines, and some DOT 5.1 fluid will be cheaper and perform just as well if not better.
