Does a new shifter really make a difference?
#26
The easiest way to add fluid into these transmissions is to pour it into the top of the trans while the shifter is off of it. By having a reusable gasket between the trans and shifter, you can take the shifter off and put it back on without having to clean off the old gasket and replace it.
#27
Should have looked first
Considering I bought the car used maybe I should have looked before asking but who would have thought it. The car already has the Tri-Ax STS in it. I apologize if any of you feel I wasted your time. For me it is a learn as you go process and that is what happened here. I now know of MGW so I learned two things. I already have an STS and I learned about the MGW STS for future reference or application. I really do appreciate all the feedback and never intended to waste anyones time. -Nuts
#28
im not reading anyones response....ill just say YES!! it makes a difference. for that matter i have my mgw shifter for sale, for a t-45. 150$ swapped to a 6 speed, cant use it. i miss it tho, have a pro 5.0 now dont like it as much.
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
