View Poll Results: what hood should i do
Voters: 37. You may not vote on this poll
HELP what hood should i get
#22
2010 Blue Ball Award Recipient
Wheres the 'Stock hood with giant holes cut randomly in it" option at?
I'll even let you use my stock hood, and I'll take your heat extractor from you.
Or, after you get this hood, you could sell me yours.
#23
Killjoy is correct. The low pressure created at the rear of the hood will draw air when moving, and exhale when still. Either way it will help to exchange air in the engine compartment with outside air better than the factory hood does.
#25
This is the real reason for the direction of airflow. Remember, air molecules, just like electricity and anything else with fluids etc are lazy and will always flow in the path of least resistance. My comment was pertaining to the comment of when you're stopped and see the heat rising out of the cowl which is why I said what I said. But yes, you are absolutely correct with the low pressure comment. Glad to see that some people know a little about basic aerodynamics!
#29
