How can I increase horse power withouth super or turbo charging?
#32
Add some notched 4V pistons to get the compression up with the above and you can get to the 330RWHP range like below:
http://www.youtube.com/watch?v=bdKuhuh72hM
#34
#35
Ha. A cai on a 2v is a showpiece cause it does nothing for power. 300 hp is not attainable on a 2v without at least a stage 2 cam and every bolt on there is. And don't believe the advertisers hype. On the air intake side the plenum is the real restriction. Swap it out for an Accufab or professional products,dragon or any larger diameter plenum will work. The tb will support your 300 hp goal. You need long tubes for sure,shorties are a waste of money and cost you torque. If your really interested in going faster forget the motor and concentrate on the rear suspension. A stock 2v can shred rubber in 3 gears so concentrate on getting what's there to the ground.
10-05-2015 06:07 PM
TfcCDR
09-14-2015 12:08 PM
M3hunter
09-05-2015 03:42 PM
