convertible top not closing correctly
our convertible top not closing correctly. When we close it the windows are on the out side of the top. The windows seam to be leaning out about a half an inch. I am not sure if top caused the lean or if the window are causing the problem. I there a way to adjust the top? The windows?
Thanks for the help
Keith
Thanks for the help
Keith
When you close the top, are you then rolling up the windows or are the windows up before?
I'm not sure if there is a way to adjust the top itself, but in the past when I didn't know better I had rolled up the windows first then tried closing the top but by doing it that way resulted in a small gap IIRC...
You never want to close the top with the windows up. Never do that. Doing that will not make the windows go out of adjustment. They move up and down. Not much else that can be done. You could have broken something by putting the top up when the windows were all the way up but going out of adjustment just seems like a stretch.
Try putting the top up with the windows down and then put the windows up.
