convertible top not closing correctly
Old 07-13-2011, 01:44 PM
luvemhot
luvemhot's Avatar
Default convertible top not closing correctly
our convertible top not closing correctly. When we close it the windows are on the out side of the top. The windows seam to be leaning out about a half an inch. I am not sure if top caused the lean or if the window are causing the problem. I there a way to adjust the top? The windows?
Thanks for the help
Keith
luvemhot is offline
Old 07-13-2011, 01:49 PM
99GTvert
is my username.
99GTvert's Avatar
When you close the top, are you then rolling up the windows or are the windows up before?
I'm not sure if there is a way to adjust the top itself, but in the past when I didn't know better I had rolled up the windows first then tried closing the top but by doing it that way resulted in a small gap IIRC...
99GTvert is offline
Old 07-13-2011, 09:56 PM
luvemhot
luvemhot's Avatar
Thanks I did not know there was a order to close the top. But I have closed it both ways. Could closing it wrong make the windows become out of adjustment?
Keith
luvemhot is offline
Old 07-14-2011, 06:18 AM
teej281
4.6L Section Moderator
teej281's Avatar
You never want to close the top with the windows up. Never do that. Doing that will not make the windows go out of adjustment. They move up and down. Not much else that can be done. You could have broken something by putting the top up when the windows were all the way up but going out of adjustment just seems like a stretch.
Try putting the top up with the windows down and then put the windows up.
teej281 is offline
Old 07-14-2011, 02:41 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
There's all sorts of adjustments available to make them right again:
cliffyk is offline
Old 07-14-2011, 02:59 PM
teej281
teej281's Avatar
I think he's talking about an adjustment inwards and outwards, like inside toward the driver/passenger or outward away from them.
teej281 is offline
Old 07-14-2011, 03:47 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
That is adjustment #6, inboard/outboard tilt...
cliffyk is offline
Old 07-14-2011, 03:51 PM
teej281
teej281's Avatar
foot-in-mouth
teej281 is offline
Old 07-15-2011, 11:46 AM
luvemhot
luvemhot's Avatar
Thanks that is what I was looking for. I will see if it works. I needed the adjustment for the inward/outward for the passenger side and the drivers sids wing window is rolling up to far.
Thanks again
Keith
luvemhot is offline
Old 07-15-2011, 12:06 PM
turbo232
turbo232's Avatar
nice diagram Cliffyk. so how do i take off the interior panels without breaking them?
turbo232 is offline
Quick Reply: convertible top not closing correctly
