2002 Mustang GT
2002 Mustang GT
Hey Guys, I'm new to this forum and I decided I'm going to put some money into my 2002.
I am the original owner of the car, it has exactly 1000 miles on it garage kept.
My new 5.0 has way more miles then the 2002.
I just have a couple questions.
Since the 2002 Is a SOHC are there any cams out there for the car without building anything?
My second question is how wide tires can I put on the car with rolling my fenders.
And Lastly what is the difference of the 2v and 4v motor? Witch one is better?
Thanks guys =)
Thanks guys =)
1k miles on it??? WOW.. good find
Unsure on your Cam question... There are many options on cams you can run with the stock motor.
You want to know, AFTER you roll your fenders how wide can the tire get? I have 315/35/17's M/T Et's For a DD right now...
On my Race starts i had 315/55/15 (i think, the height was 55) and they rubbed... Too tall. Going to roll my fenders soon. Kinda wasted $500, Shredded my Et streets to nothing..
I have a 2004 gt with 60k on it , and as far as i know the 2 valve 4.6 is a double overhead cam. A 4 valve motor breaths better revs higher and produces more high rpm hp. Since your 2002 is garage kept can you post pics, i'm amazed to hear you kept the car so long without driving it much...
If you want cams that you can just drop in, without upgrading valve springs, and that will work really well with the stock motor, then check out Modular Head Shop. I have their stage 2 cams, and they loose no power down low, make good power up top, and have a nice choppy idle.
If i'm not mistaken about the widest tire you can go without rolling the fenders is around a 315. At least if your around the stock diameter. If you run a taller tire that might change things.
I found the Comp Cams Stage 1 Xtreme Energy Any good? I want that cam sound, but not loud just a little choppy. As for Daily driver manageable.
And any opinions of the Magnaflow MagnaPack Catback Exhaust and
Magnaflow Catted True-X X-Pipe.
dude w/ only 1k on the motor, you still got some breakin in to do! get that engine to at least 5k miles (with easy, non-high-rev driving) before doing anything to it.
