Projectors wont aim on low and hi-beams at the same time.
Ive been outside trying to get these things aimed right for over an hour, managed to kill my new battery doing it...
I got these projectors used last week and they fit fine, I thought I had em aimed until I tried to use them last night, the lows were not bad but the highs were not hitting the road at all, they were about 20 feet off the ground @ 100feet away...
so I tried adjusting the top adjuster and that got the highs down some but now the lows are too low...so I found the 2nd adjuster...now they are not matching left to right...
FOr instance now the lows will be even, but the high on the left will be higher. if I try to lower it, then it reverses sides...
What is the lower adjuster for, and is there a write up on aiming projectors?
Mine are exactly the same way
I have no solution for it, but spend quite a bit of time looking at them to see if I could find a way to rectify it, but cannot. I ended up doing some tricky wiring to allow the low beams/high beams to be on simultaneously. I also wired the fog lights to be on with them as well.
Projector headlights mod
foglights mod
Jazzer
foglights mod
Jazzer
Still have to get the spread patterns set.
Matt's 95 Stang
10-05-2015 07:16 AM
