Throttle Body and Plenum: Stack Racing vs. Accufab
#31
i understand what you're sayin cliff, but some people complain about the dragon, sayin it has a whistle and/or leak; and other complaint i've heard abt various plenums is that they don't mate up properly with all the plugs and whatnot. i was just curious if anyone here had experience with the stack racing plenum to see if any of those issues were existent
#32
One problem was as I understand that end users did not seem to understand the value of using a permanent type grade of Loctite (one of the red flavours) on the screws and a few customer's engine ate them and parts of the fins.
speed UNLIMITED welded the standard fin to the top plate and liquidated the lot of them...
¹ - I don't know what the people at Granatelli smoke, but there are times I wouldn't mind having some.
#34
Well you know, the whole history of the "Shark" plenum should serve as a grand example of why one should not believe the pile of BS that accompanies a whole lot of aftermarket stuff.
If someone says that bolting on their particular piece of oxenscheisse will add 20 HP, then it is very most likely a crock of the same.
As to the "whistling", a good part of the decision making process for OEM components is NVH--Noise, Vibration, and Harshness. Very often performance is a secondary criteria...
#35
And for the aftermarket, those are reversed. I like the whistle. Mine does it a little bit now. If you clean the TB with carb cleaner to clean the gunk from the flap to make it less sticky, they will whistle a little bit. The one I might get eventually will probably whistle a lot.
Cliffy, if one had plans of forced induction not too far down the road, would you suggest one of the larger offerings on the market to prepare for it?
#37
Well when forcing air into an area, you create pressure. Now, moving air into a larger space will create less pressure, but still allow the same amount of air to be moved. Essentially making the system more efficient. So you're right on the money on that one.
#38
That big-*** 78 mm BBK integrated unit is likely as close to optimal for f/i when using a centrifugal blower or turbo charger setup; real superchargers feed directly into the intake manifold so the upper plenum goes in the trash anyway.
For the ease of resale scenario presented above I can think of no reason to hobble n/a performance because "someday" you may want to go f/i--unless perhaps someday is next week...
