SVT Focus fuel pump size/measurements
Hey guys, I had a quick question for you all. I'm looking at fuel system components, as there have been a lot of new fuel system technology that's hit the market in the last 2 months. There are new pumps out there that are(I'm thinking) about the same size as the focus pumps and will flow 340lph(New Aeromotive Stealth pumps and the Lethal Stryker pumps). They both will work in return or returnless and I was just wondering what the dimensions of the stock pump and the focus pump are so I can map out for fuel system plans in the near future.
Thanks for your help guys! I appreciate it!
Teej
Teej
They fit a cobra hat for sure, but you'll need to run either a GT500 pump harness or a dual FPDM setup if keeping it returnless. You can convert a Cobra hat into a return hat by welding on a return bung into the hat next to the outlet. Lemme see if I can find the thread on SVTP that you could do it with. You use the stock feed line as the return and then a larger feed line.
Edit: Found it!
http://www.svtperformance.com/forums...lth-pumps.html
Edit: Found it!
This looks promising. Ill probably just get a gt fuel hat and modify it to hold 2 pumps. Itll be much cheaper in the end. I just need to figure out if I want to go return or returnless. theyll cost about the same.
From what I've gathered, I'm going return when I can. Less electronics and stuff like that. And to be honest, if you're only wanting enough fuel for 500-550rwhp, then one pump would probably be plenty for you.
I'm trying to figure out the size of the focus pump to compare to the Aero/LP pumps and see if it will fit in the stock hat.
Ill probably just stay with one pump then. Do you think the stock fuel lines are big enough for mine? If so, Ill build it for around 500-550hp and up grade it more later down the road. This way I can get the build done quicker and not have to wait as long for cash flow.
Also, sorry for thread jacking you.
That's what it's looking like. It's the same size as the walbro in tank pumps so it should fit. Also, I think it's be worth it to upgrade to a larger line. That's just me though.
Ill probably get the black braided -8 line and use that to replace the line and use adapters to fit the line to the hat and rails. Do a returnless system for now. Keep it lower budget. If I find a BAP for a good price, ill probably add that for safe measure.
mrappe
09-26-2015 10:16 AM
2003, 340, aeromotive, cobra, focus, focuse, ford, fuel, inspection, irs, measurements, pump, size, stealth, svt
