Old 10-08-2015, 01:40 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
removing lower ball joint?
Old 08-29-2011, 12:41 AM
Blk003GT
Blk003GT's Avatar
Default removing lower ball joint?
what is the trick to removing the lower ball joint from the knuckle? its a qa1 tubular arm only been in there for like 4 months. i never can get the ball joints to separate i don't know what i do wrong. what is the trick? i just seems like a pickle fork never works for me
Blk003GT is offline
Old 08-29-2011, 12:47 AM
Bpohlman13
Bpohlman13's Avatar
I always took the nut off and hammered the side of the knuckle close to the ball joint and it would come off easily. You could also hit the top of the ball joint by setting a peice of wood on top of it and hitting it with a hammer.
Bpohlman13 is offline
Old 08-29-2011, 05:32 AM
uberstang1
Chupacabra
uberstang1's Avatar
I take the crown nut off then thread it back upsidedown till its flush with the stud and just smake it with a hand held sledge and it falls right out.
uberstang1 is offline
Old 08-29-2011, 08:45 AM
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
Like mentioned above, hit the sides of it with a hammer. It may take some convincing but it will eventually fall out. If that doesn't work you can do like uber said and use the nut and hit the top of the stud.
I would stay away from the forks that people use as that usually does bad things to the boot.
WannaBeGearHead is offline
Old 08-29-2011, 10:06 AM
BlackMage
BlackMage's Avatar
same as what uber said, hit it with a large hammer. make sure the nut is upside down and the threads are protected by the nut.
ive never had good success with pickle forks, always seem to rip the boot real bad. lol
BlackMage is offline
Old 08-29-2011, 02:34 PM
Brute03
Brute03's Avatar
is there any way to get the ball joint out of the arm without that press tool? i'm trying to avoid buying one considering i'm probably only gonna use it once and i can't even rent one around here
Brute03 is offline
Old 08-29-2011, 02:48 PM
BlackMage
BlackMage's Avatar
cut the a-arm apart to get at it??
possibly a large c-clamp and large socket.
Old 08-29-2011, 03:08 PM
Brute03
Brute03's Avatar
or can i just hammer it out? there must be a shade-tree way of doing this
Brute03 is offline
Old 08-29-2011, 03:12 PM
BlackMage
BlackMage's Avatar
that thing is pretty solid in there. You could try heating up the a arm and then popping it with a hammer.. but i doubt you will see any movement. I think you would run into the problem of keeping the a-arm solid while you hit it with a hammer, the bushings would absorb most of the blow.
although, you are NEVER supposed to heat up suspension pieces.
Old 08-30-2011, 05:25 AM
uberstang1
Chupacabra
uberstang1's Avatar
Large c clamp and socket is the only way really besides the tool.
Quick Reply: removing lower ball joint?
