So it's begun.
So it's begun.
So i finally started the V1 project i'm taking on this winter going into the spring. I went with piecing it together the way I wanted to save money and well It's nice to choose not save up all at once and drop a ton of cash all at once on a supercharger kit, but having that extra grand in your pocket is nice. ;]
In the pic:
1. Bracket Assembly
2. Discharge Assembly
3. Air Intake Assembly
4. Oil feed
5. Oil drain
I've decided to make the setup an inter-cooled setup as well, I'm gonna go with a CXRacing Kit: http://cgi.ebay.com/ebaymotors/CXRac...mZ250549906760
Injectors, I was recommended: http://fuelinjectorconnection.com/sh...d&productId=35
My question is has anyone tried them, and if theyve had any problems with them at all?
Lightning 90mm MAF
SVT Focus Pump
Then i'll top it all off with a dyno tune at New England Dyno, unless someone has a recommendation for any other professionals in Worcester County Area, Massachusetts.
In the pic:
1. Bracket Assembly
4. Oil feed
5. Oil drain
Lightning 90mm MAF
SVT Focus Pump
Ask for Jon Banner , he is the man when it comes to FI.
I bought a set of Boshe III (PSI Matched) for my wifes 93 Corvette and I tell you it is a new car.
As for NEDT do good work there but there is a place if you want to travel providing you has a SCT to load a can tune in to get you there safe.Its in NH called Dez Performance . I hear he is top notch in our area and believe only does Mustang tuning and uses SCT.
Hope to catch you around, BTW theres a carshow at Heberts in Shrewsbury i will be there with my 99 Mustang GT (black) Cobras staying home, need clutch
GL on your build
Repzard
So after a little more research and reading about the intercooler setup my discharge assembly is pretty much useless to me? Maybe someone can throw me in the right direction. Parts are listed up top for what I plan on going with. Feel free to throw in other parts you may recommend.. I have all winter to part this project together and I'd like to get it done in one day without having to search for parts, then drive it on the trailer to get it to Dez Performance Racing.
RedlineGoods.com
01-12-2013 02:24 PM
JoelEsler
03-23-2010 11:08 PM
10GTSTANG
02-22-2010 09:04 PM
