4.30 or 4.56
4.30 or 4.56
I have a 2002 mustang gt, comp 270 cams, 78mm bbk throttle intake, professional products intake manifold, S&B coldair intake, underdrive pulleys, BBK long tube headers, 3.55 gears, SCT tune, 30lb injectors, 255lph fuel pump, 275/50/15 nitto 555r's, zoom stage 3 clutch and a T-56 6-speed transmission(1st 2.97 2nd 2.10 3rd 1.46 4th 1.00 5th .74 6th .50). Last time I had it at the strip I ran a 2.0 60ft 13.3@103mph @5000rpm. I can rev up to 6500 and make power, so shift about 6500. I am leaving it N/A so I want to gear it as low as I can. I was thinking that 4.30 would be as low as I should go. I want to get as many opinions as possible, Thanks
Im running 4.30s and my car is N/A as well, obviously. Thats the gear that I need to run at the track with my tire size and powerband. If youre gearing it to optimize track times, then it depends on what youre tire size is, where your car makes power, etc. If youre looking for fun on the street, then its really up to you...
