improve gas mileage??
Wuddup just wondering if there is any tips on how to get better MPG?? Like replacing spark plugs or what not.. Any tips helps! =)
Best advice is drive like a grandma. Usually driving habits have the most effect on the cars gas mileage. Other things that can contribute to bad gas mileage are old spark plugs, bad coil on plugs(spark plug wires), bad O2 sensors, higher ratio gears, dirty MAF, dirty fuel filter, dirty air filter, and low air pressure in tires.
Originally Posted by DjBootleg813
(Post 7796360)
A dirty TB and fuel filter did a number on my gas mileage
Originally Posted by Rockwell28
(Post 7796631)
Whats your current mileage?
Sounds about right to be honest. Most likely you are being a little too hard on the throttle and on the brakes in the city. Nothing major to worry about, but driving a little more cautiously will get you around 17mpg in the city. 25 on the highway is far better than what I get though. Bastard
(Post 7797210)
like 14 -15 city and like 25 highway =/
Originally Posted by Kerns
(Post 7796507)
MY modo is i pay to play and its the truth reving/showing off/burning out/ or gunning the hell out of it will get you no where but a ticket and more cash flow into the car ;) but its worth it. |
Yup, driving habits have more to do with mpg than any other single item.
Put some broken glass in your right shoe and your mileage is likely to improve. Your current mpg don't sound much out of line though. The mileage in town could probably improve a little with changes in driving habits. Slow your rate of acceleration from lights and stop signs. Coast up to lights and turns instead of using gas all the way there and brakes at the last minute. If you have a bunch of crap in your trunk, take it out. Extra weight is not good for mpg. General maintenance is also required (filters, plugs, tire pressure, etc). |
