04 Vortech Build 3-10-12 (Lots of pics, warning.)
#21
I think you can reach it or get damn close to it. through that tune since you're intercooled.
http://www.moddedmustangs.com/forums...ock-motor.html
#23
Im making 396rwhp with stage 1 N/A cams and I have a auto trans too. And a svt focus pump
#24
Setup is: Vortech V1 S-trim
3.33 pulley
Anderson powerpipe
Cx Racing Intercooler
3" piping with a Pro-M MAF
42 injectors
SVT Focus Pump
I think ill be ok getting to 375-400 but well see. Was told the 3.33 will get me to 8-10psi.
3.33 pulley
Anderson powerpipe
42 injectors
SVT Focus Pump
#25
if its through an auto you wont reach 400 id say more like 375-385rwhp, if you're through a manual 400-410rwhp should be achievable
#27
your tuner most likely tuned you down with a safe tune assuming you're on a stock block. over 400 can be achieved with that setup, i hit it when i had my procharger and when i had my vortech with almost the same setup.
#29
Im sure it will be possible. Thanks man! Thats exactly what i said in the fall when i sold my r6 and i started with the $1500 vortech build thread info. Bit the bullet and 6 months later this is the result. Dyno day is tomorrow at around 11-12 ill have footage and pics for you guys with the results from Mike Dez.
