What could this noise be?
To me that video does sound like a wheel bearing (groaning noise).does the noise change pitch or loudness the faster you go?
If so order yourself a hub ,its bad.(Btw its a real easy job if you work on your own Mustang)
GL 69MC393cid
Im guessing it could make noise and have no play.All it takes is a small flat spot or little grease when put together.(defects happen but not usually with a good quality bearing like Timken) cheaper ones ...Sure.
GL 69MC393cid
GL 69MC393cid
Thanks
Yes, louder I go it gets higher pitched, if I go slower its more of a groaning/grinding and recently it seems to be getting louder. Anyway to check to know for sure if that's what it is? Also yes I do my own work, what all do I have to do to swap it out? It's not press fit? Is it one of the bolt in kind?
Thanks
Thanks
but a simple test would be to take off the caliper (to eliminate that as cause) spin the hub and see if you hear any type of noise at all.bearing are pretty quiet when theyre not bad but under load can be quite noticeable.
To change
If I remember ( like 4 years ago when I changed both on my GT ) its very similar to the old school rotor and spindle style.
One bolt in the center that holds on the bearing and hub unit after you remove plastic center cap .
May have to use a steering wheel type puller to remove it if it doesnt slide right off.
I know it was a easy job and didnt have to rent any special tools.Straight forward job for the DIY Pony fixer
Its no doubt a bearing what you described above.
To change
To change
Anyone going to be in Carlisle that wants to go for a ride and hear this to help figure it out? It's driving me nuts. Haha
So I had a mechanic go for a ride with me and he said he really doesn't think it's a wheel bearing that he hears. I did discover something though, the sound seems to get louder as the car warms up, it's not there when the car is cold. Takes a couple minutes to start and gets to its worst point after 5-10 minutes of driving.
He said it could be the wheel bearing grease thinning out but he doubts it. Maybe this is caliper related? Man this is annoying me, as soon as I figure this out I'm posting up what it was so hopefully it can help someone else out in the future.
