4.6L Help! Getting Codes for incorrect Voltage
I dont have a mustang, I have a 1994 Lincoln Town car. I cant find any sources after searching for a fix.. this is the closest place to find. I'm sorry. I need help.
I got codes 53 55 58 and 95
All the codes have something to do with Voltage to high
53 Throttle Position sensor too high - TPS
55 No or low (under 7.5 V) Key Power to PCM pin 5
58 Idle Tracking Switch (ITS) signal problem ISC
Vane Air Temperature (VAT) sensor out of range or open - VAT
95 (O) Fuel pump: open, bad ground or always on - Power / Fuel Pump Circuits
The car is running. CEL comes on after driving. Restart clears it. Runs rough at idle and sometimes cuts out at stop lights.
I checked all my wires, and checked the alternator. The looked OK.
What else can I do? I hope I'm not out of place asking here, but I need help from you ford guys.
All the codes suggest a voltage issue. :[
Got any idea's I can follow to root this out?
Bad alternator? Voltage regulator?
I dunno.. maybe someone could help... thanks anyways.
As a guess and being that you believe it's an overvoltage issue, then the first thing I'd have checked is the voltage regulator but that should be integral to the alternator.
jwog666
12-27-2021 08:09 PM
