So if you've been reading my lastest posts you know I've been havin problems with my baby... I lack knowledge in the car world.. So I guess I just have to give in and take it to the shop tomorrow =(.. It keeps gettin worse.. My car just dies out when I'm idling.. Raw fuel dumpin out the back.. Runnin lean sometimes... One thing after another!
Another grabber blue SN , everyobe copying meeeeee. Lmao just kiddin, certainty there must be a check engine code?
codes....
P0136 OX S CIR
P0141 OX S HTR
P0156 OX S CIR
P0161 HTD OX S
P0171 SYS TOO LEAN 1
P0174 SYS TOO LEAN 2
P0304 FALT CY E MSFR DET CY 4
P0352 IG VOL B PR SEC CIR ER
P1000 MONITOR CHECK BOT COMP
P1100 MAF S CIR
P1132 LACK OF H02S1 SWT RICH
Like I said, O2 sensors and the MAF. The MAF could be effing up and causing the the A/F to be off, which is making the 02's read funny, but odds are, they are due for replacing anyway. Clean or replace the MAF, then go from there, still messing up, change the O2 sensors and your car should be good to go.
Raw fuel dumping out the exhaust? That means that you also have fuel in your oil.
Plus the excess fuel will "wash" the cylinder walls and can cause a lot of wear issues fairly quickly.
