want to guess my project's HP/TQ??
Old 07-29-2012, 02:21 AM
darkstarnes
darkstarnes's Avatar
Default want to guess my project's HP/TQ??
Well after several years I am finally putting back together my project engine a "B" head DOHC engine... and it consists of these parts:
forged rods
forged flat top pistons
cobra crank
balanced rotating components
P&P heads with swirl polished valves
1 1/2 cut intake runners
delete IMRCs
steeda UDPs
aluminum Flywheel
and I have a question... I bought used ARP head studs (I know what a cheap bastard) well it did not come with the instructions so if anyone knows the torque specs I would really appreciate them..
darkstarnes is offline
Old 07-29-2012, 09:50 AM
uberstang1
Chupacabra
uberstang1's Avatar
300-325 horsepower
uberstang1 is offline
Old 07-29-2012, 11:33 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
334 at the wheels
and for your torque specs.. http://arpinstructions.com/
WhiteFoxGT is offline
Old 07-29-2012, 03:58 PM
darkstarnes
yep I was thinking between 320-330 hopefully... "B" heads aren't the best...
and thanks white fox didn't know of that website...
Old 07-29-2012, 05:44 PM
darkstarnes
Oh wow it says to screw the studs into the block only hand tight... that sounds scary -_-
Old 07-29-2012, 06:24 PM
JC316
JC316's Avatar
Same way with my Super Coupe. I wouldn't worry, that was the only item that never did break on my SC.
JC316 is offline
Old 07-29-2012, 06:37 PM
1998Slow 'Stang
1998Slow 'Stang's Avatar
Actually depending on the application they are the better between B and C
1998Slow 'Stang is offline
Old 07-29-2012, 06:49 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
That's normal. Also, since you said they are used, I would skip the part where it says to cycle them to pre stretch the studs.
Old 07-29-2012, 07:28 PM
darkstarnes
Yea I heard that B heads are better for F/I but since I am going N/A they are not the best heads for that... I will eventually spray on the motor so its ok...
lincolnshibuya
12-08-2015 04:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
BeatnikFink
10-01-2015 08:00 PM
Drastang
09-30-2015 03:48 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: want to guess my project's HP/TQ??
