Sensor 2 bank 1 stuck lean , need help
Hi i have 2004 gt , x pipe, borla cat back, with MIL eliminators on the o2 sensors that are located after the catalyc converter, that used to be there.
Everything was cool until yesterday, when i have engine code
Sensor 2 bank 1 stuck lean.
Now the car uses lots of gas. I dont understand, i would think that sensors readings are eliminated using the MIL eliminators, that is why they are there.
I would appreciate anybody's help.
Thank you
Thank you
I did not get the exact code, i just got the message on the reader,
and was sensor 2 bank 1 stuck lean.
I have to go to rescan it again to get the actual code.
The guy said it was pasenger side after the cat. converter.
I suspect it was code P1151, Lack of HO2S-21 Switch, Sensor Indicates Lean.
Sensor HO2S-21 is bank 2 sensor 1 (front)--which would cause the engine to run rich as the O² sensor is telling the engine the mix is lean. The PCM will make the mix richer until it has added more than 25% additional fuel, at which point it will throw the DTC...
