2v guys, What brand and weight of oil and filter do you use?
#32
I run red line 5w40 w/ FL1hp filter, Oil changes range depending on type of driving, amount of driving, and how the dipstick looks. I've gone up to mostly between 5000-7500, if I'm pushing it hard then 3k. I work at a motorcycle shop and talk to a few oil reps and they consistently run their cars to 10k and bikes to 7500-10k, one guy does an oil change on his suburban every 22k miles (he found that interval by running oil analysis's of his SUV for his company) .
What I was told and have found a few sites backing up the claim, is that all oil has additives in it, the percentage of this additive is normally in the 5% range of the total volume. Within that 5%, about 75-90% (from what I was told by reps without giving me too much info) is wear/friction reducers and the rest being detergents. The detergents are designed to clean off contaminants and strip off the old oils' wear/friction reducers film. This (again was told this) normally lasts for the first 1,000 miles and while the new oil's friction/wear reducers are being pressurized/heat bonded to new wear areas of the engine, while this process takes place the engine is actually under more strain since there is no longer a layer of the reducer on these high wear areas.
Anyways it's late and I'm sleepy so I'll post up a quick link I just googled to explain the rest. I'll post up other info I was told by a few of the oil reps while they visited us, to some extent that is.. not supposed to be giving specifics.
http://forums.tdiclub.com/showpost.p...4&postcount=27
#34
The argument regarding "improved and tighter manufacturing tolerances" can be easily disproven by comparing the component specs and wear limits for any late 60s and contemporary engine--you will find they are the same...
#35
I know this is an old thread...but I just wanted to say that I run mostly 5w 30 Motorcraft oil with the 820S filter. No problems. I ran Castrol Full Synthetic and did not notice a difference between the two.
inyadreems
08-21-2015 09:10 AM
