Need Help With Rear Diff Leak
Old 08-10-2013, 03:18 PM
yfm909
yfm909's Avatar
Default Need Help With Rear Diff Leak
The other day I went to get an exhaust leak fixed and while it was on the lift I saw that the differential was leaking in two places. It's leaking where the axle shaft connects to the diff. It is also leaking on the rear drivers side axle, it's not brake fluid. I'm new to the car stuff and any help would be great.
Here are a couple of picture to give you an idea, what could it be and what do I need to get it fixed? Thanks
yfm909 is offline
Old 08-10-2013, 03:25 PM
Gary Ugarek
Gary Ugarek's Avatar
Pinion Seal... $28.00 part about 2 hours labor
Gary Ugarek is offline
Old 08-10-2013, 03:28 PM
yfm909
yfm909's Avatar
Would that fix both leaks?
yfm909 is offline
Old 08-10-2013, 03:49 PM
Gary Ugarek
I just saw the pumpkin leak... The other is an axle seal, all together parts and labor would probably be about $200-$300 (Estimated)
TfcCDR
09-14-2015 12:08 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
MusicCity615
09-12-2015 07:05 AM
09-08-2015 11:50 AM
Quick Reply: Need Help With Rear Diff Leak
