Best suspension mods
Okay so i already have some suspension work but i was wondering what should be my next mods to hook up at the drag strip? I got eibach pro damper shocks & struts and its dropped 2 inches im not sure on the brand of the spring though it's a 99 gt
rear lca i recommend j&m weight jacker adjustable ones, quad shock delete, steeda x2 ball joints, steeda bump steer and may want to look into some better shocks/struts like bilstein or koni if you are dropped 2"
For the drag strip, solid lower control arms (heim joints), solid adjustable uppers with pinion angle at -2 degrees. Strange 10 way adjustable shocks/struts. Loose the lower springs and run a stock spring with 1 coil cut.
They will help with the body flex (and on the street as well), get some weld-in Full length Subframe connectors.
Also make sure you running a good tire. .
What does the car run now and what is your target ET? Is it a daily driver?
An IRS will make you hook at the track
It's my daily driver i got nitto nt555r's in the back i just want the car to hook anywhere (drag strip/street) with no problems and not mess up the ride either beacuse its kinda ****ty lol can ya'll post some links of the MAIN things to get?
The fastest ive ran at the quarter mile is 14.00-.- with bbk cai,bbk x pipe,3.73 gears,accufab 70mm tb, sct bama tuner,and the nitto nt555r's like i said
Good deal. I just bought the 555r's also. Can't wait to get the car back and mount them. What size are you running?
