Motor Swap - Auto to Manual
Old 02-25-2014, 11:16 AM
CJCuster89
CJCuster89's Avatar
Default Motor Swap - Auto to Manual
Just looking for some insight or feed back. I threw a rod in my 2002 GT. Luckily for me I found a motor about 4 miles from my house in a 1997 GT with only 21,000 miles on it. The motor is coming out of an automatic and my '02 is a manual. So basically my question is, the only thing I should have to do is remove the torque converter and the flywheel and bolt my stuff on right? I ordered a stage 2 clutch kit and I play on getting my flywheel resurfaced instead of buying a new one. This should all work out right? Same motor just different year, and a torque converter removal.
CJCuster89 is offline
Old 02-25-2014, 02:31 PM
PurpleIcedGT
PurpleIcedGT's Avatar
Why would you drop an NPI motor into your car?
PurpleIcedGT is offline
Old 02-26-2014, 08:12 AM
CJCuster89
CJCuster89's Avatar
Because for one, I'm broke and I got this motor with 21,000 miles on it for $400. And I plan on doing a huge motor overhaul to it anyways. I already have a new intake manifold, headers, bigger throttle body, injectors and other various things. I just couldnt afford a PI motor. Plus I'm not really building my mustang for super speed. It's more of a show car.
Old 02-26-2014, 09:40 AM
PurpleIcedGT
Wait did you already buy it? We're talking about a PI 2v motor here, not a coyote 5.0.....
PI 2v motors can be found for 350-600 bucks tops.
If you already bought the NPI, I suggest swapping for PI heads. Absolutely nothing positive power wise will come from an intake manifold unless you are building the motor to rev the #**** out of it. Injectors are worthless and throttle body doesn't do anything but a slite better throttle response.
Best mods for the 2v are longtubes, 4.10s/4.30s, suspension/tires and a savings account for a supercharger. Everything else is just plain marketing horseshlt.
Best of luck
Old 02-26-2014, 03:03 PM
CJCuster89
CJCuster89's Avatar
Yes I already bought the motor. I'm not really looking to get that deep into it. As long as the car drives good and sounds like a V8 i dont care how fast it is. This car is basically my project car to look beautiful. That's basically it. Just need a motor to make it go, some engine dressup and a new paint job.
Old 02-27-2014, 07:05 AM
PurpleIcedGT
Oh....okay. Well then, best of luck.
Old 02-27-2014, 11:06 AM
CJCuster89
CJCuster89's Avatar
Thanks.
Old 02-27-2014, 11:29 AM
BraMas
BraMas's Avatar
consider keeping the heads and intake from your blown engine becasue some day you will realize what a mistake it was putting a NPI engine in your car and you can just swap the heads and intake over
BraMas is offline
Old 02-27-2014, 03:29 PM
PurpleIcedGT
I agree with @Bramas
Old 02-28-2014, 01:43 PM
CJCuster89
CJCuster89's Avatar
Well I mean like I said in my earlier replies. I'm not looking to make this car a race car. I basically need the motor to make it go. Everything else I'm just turning it into a visual show car. I'll probably never run it on the track.
Granatelli Sales
01-20-2020 12:34 AM
97SN95GT
09-13-2015 09:45 PM
Brian Emmer
09-09-2015 02:50 PM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: Motor Swap - Auto to Manual
