Fuel Rail Delivery Set up ?
Hi,
Fuel set up is a Walboro 455 with a Kenny Bell Boost a pump and the delivery setup to the rain where the fuel is delivered is a little problematic being there are to many options for it to fail. There are 3 fitting connecting the fuel line to the rail and i feel there has to be a better way Link to the Pictures below
http://imgur.com/a/JIdHJ
Thanks Justin
Thanks Justin
Hi,
Thanks Justin
Thanks Justin
Exterior
• FoMoCo Cobra Nose Piece
• Toyo Tires 285-35-18 (Rear) 275-35-18 (Front)
• Chrome Bullet Style wheels 18x10 (Rear) 18x9 (Front)
Under the hood
• Fresh Roush 4.6 Bottom end
• New Melling Billet Steel Oil Pump
• Ford Racing P1 Heads
• ARP Main Studs & Head Studs
• Cometic Head Gasket ( all new gaskets and seals @27,100 miles)
• Modular Power House Custom Grind Blower Cams (550 Lift Tim Barth)
• Comp Cams .600 Lift Springs
• Adj. Comp Cam Gears
• Ford Racing 42lbs Injectors
• Trick Flow High Heat Intake
• BBK Ceramic Coated Long Tube Headers
• BBK X Pipe
• Flowmasters
• Modular Power House Intercooler
• Vortech Mini Race Bypass
• Vortech SQ-V1 Supercharger 5lbs of boost.
• Spec Stage 3 Clutch and Pressure Plate
• Spec Billet Flywheel
• Kenne Bell Boost-A-Pump
• Walboro 455 Fuel Pump
• New FoMoCo gas tank
• New Ford X4 Flash Programmer
• Steeda Clutch Adjustment.
• Steeda Firewall Adjusters
• 373 Gears with HD Carrier
• Diablo Sport MAF Extender
• Modular Power House Pipe
• Tuned by Eric McMillon at Speed 365 Martinsville VA
• Tuned on 93 Octane on 5lbs of Boost 490HP 429RWTQ
im not quite sure what your question is? It appears (flash would have been helpful) that you have a fuel pressure sensor tapped in to the test port on the fuel rail. Are you looking for another option to mount that?
With a pump that large did you modify that stock tank? modified fuel basket? What about the fuel lines? Still using the FPDM and no return setup?
Just helped my buddy put his car together... used a modified tank, ran -8 feed and return lines with adjustable regulator, to a FORE fuel rail and 60lb injectors. Has a FORE fuel hat with a hobbs switch to activate the second pump under boost.
