WHAT PI HEAD AND INTAKE COULD I HAVE?
WELL I LOOKED EVERYTHING UP WITH THE NUMBERS I FOUND AND THE INTAKE COMING FROM THE DRIVERS SIDE THAT THESE ARE 2003 PI HEADS AND INTAKE ROMEO MOTOR.SORRY THAT YOU SAY DONT WASTE MY TIME BUT I NEED TO FIX THIS.AND THATS ALL THERE IS TO THAT.11 BOLT VALVE COVERS AND OIL FILL ON DRIVERS SIDE 3 SEPARATE GIRDLES AND SLIDE ON NOT PRESSED ON CAM GEAR.AND NUMBERS SAYING ON THE CASTING PI HEADS .....
PI HEADS AND INTAKE
The casting number is on the head itself on the right side it will be near the first exhaust runner.
No need to waste your time from looking at the cam cover it's NON PI the left hand oil filler cam cover will not fit a PI head and that's all there is to that.
I did a comparison on this forum of going out buying used PI heads, gaskets, head bolts, antifreeze, oil, filters and so on and the cost came in somewhere around $750.00 to $800.00
I found an 2005 Lincoln motor with 55K miles for $500.00 and swapped it Did it for $800.00 but i bought a new FORD Racing intake, P.P. plenum and a few other parts
PI HEADS AND INTAKE FROM 2003 GT ROMEO MOTOR ON 96 GT ADDED 2nd COOLANT SENSOR ALSO.1
WELL I FOUND THE NUMBERS ON UNDER HEAD AND THESE ARE PI HEADS FROM 2003 MUSTANG AND ALSO PI INTAKE,UNDER VALVE COVER 3 SEPARATE CAM GIRDLES AND THE CAM GEAR IS SLIP ON NOT PRESSED ON THESE ARE ROMEO HEADS AGAIN OFF 2003 MUSTANG..SO I DONT KNOW WHERE U CAME UP WITH DONT WASTE YOUR TIME CAUSE I DID AND THE OIL FILL IS ON DRIVERS SIDE AND SOMEONE DRILLED AND PUT 2ND COOLANT SENSOR ON THE INTAKE.SO THATS ALL THERE IS TO THAT AS YOU SAID.....THANKS THOUGH FOR YOUR HELP JEFF
PI AND NON PI VALVE COVERS FIT
SO IF U HAVE A 03 AND 04 ROMEO BLOCK AND HEADS THEY HAVE 11 VALVE COVER BOLTS AND A WINSOR HAS 13 AND 14 CORRECT? SO WOULDNT A 03 AND 04 ROMEO VALVE COVER FIT ON A 96 ROMEO NON PI HEAD? ?????
